What are Hivium's nameservers for Enhance Control Panel?
When updating your domain’s nameservers to point your domain to Hivium Hosting, you will need to use the following nameservers:
ns1.securehostedserver.com
ns2.securehostedserver.com
Related Articles
What are Hivium's nameservers?
When updating your domain’s nameservers to point your domain to Hivium, for your WordPress or WooCommerce hosting you will need to use the following nameservers: ns1.securehostedserver.com ns2.securehostedserver.com If you have any further questions ...
When updating your domain’s nameservers to point your domain to Hivium, for your cPanel Web hosting you will need to use the following nameservers: nycns100.cpanelhostserver.com laxns100.cpanelhostserver.com If you have any further questions or need ...
How to manually install WordPress in Enhance Control Panel?
This article will guide you through the steps to install WordPress manually in the Enhance Control Panel. Follow the steps below, 1. Create a domain from the domains section in your control panel as shown below. Click on the advanced option and enter ...
How to add a new domain in Enhance Control Panel?
Instructions to add an addon domain in the Enhance Control Panel Here is a step-by-step guide Step 1: Log in to your account and select the website that you would like to add your new domain too. Step 2: Click on the Domains option, and then click on ...
How to install a SSL certificate in Enhance control panel?
The article guides you through the steps to install an SSL certificate when using the Enhance control panel. 1. Login to your account at https://hub.hivium.com 2. Select the website that you would like to secure with an SSL certificate. 3. Go to the ...
