How to change the upload_max_filesize variable while using cPanel?
The article guides you through the steps that need to be performed to change the upload_max_filesize variable while using cPanel control panel.
If you have received an error such as "The uploaded file exceeds the upload_max_filesize directive in php.ini", when trying to upload files, you can follow this guide to increase the maximum upload size. While you may be receiving this error in WordPress, to fix it you'll need to log in to your cPanel account.
1. Log in to your cPanel account.
2. Scroll down to "Software" and select the option "Select PHP version".
3. Select the "Options" tab beside the "Extensions" tab on the top.
4. Scroll down to the label which says "upload_max_filesize".
5. Select the appropriate value according to your requirement.
6. Once set you will see a message saying "Success - Option upload_max_filesize successfully saved" in a green color on the top right hand side.
If you need any further assistance, please create a ticket with us!
    • How to change the DirectoryIndex while using cPanel?
      The article describes the steps to change the DirectoryIndex while using the cPanel control panel. The Directory Index is an .htaccess code that specifies the default page for your domain name. The .htaccess file is recursive - if you place it in ...
    • How to change your cPanel Password?
      The article describes the steps to follow to change or reset your cPanel Password. Step 1: Log in to cPanel Step 2: Click “Password & Security” in the Preferences section. Step 3: You can change your password by filling in the fields and clicking ...
    • How to change file permissions through cPanel?
      To change the file permissions when using the cPanel control panel, please follow the below steps, 1. Login to your cPanel account. 2. Select the File Manager option. 3. Select the file whose permissions you would like to change, and choose ...
    • How to connect via FTP when using cPanel?
      Connecting to your server is fast and easy when using FTP access. Hivium has the cPanel File Manager that you can use to upload files to your server; however, the File Manager requires you to upload one file at a time. With FTP, you can upload all ...
    • How to change the PHP version for my websites?
      The article will guide you on the process of how you can change the PHP version for your website while using the Enhance Control Panel on your VPS. 1. Once you have logged in to the control panel at https://hub.hivium.com, select the website you need ...
